Cash problems
17 years 2 weeks before #5443 by manual-mecanica
Cash problems posted by Manual-Mecanica
Good, if someone can give me a help, I have a Nissan Mistral 96, Automatic Box, when it is underway there are times that is accelerated and does not change the speed ...
I had to try for a mechanic but just at the time of trying it did not do that problem but he told me that it would be a voltage watermaker?
thank you.
17 years 2 weeks before #5476 by manual-mecanica
Manual-Mecanica Response on the Re: Cash Problems
I would try to change the combination filter. (Box C)
17 years 2 weeks before #5477 by manual-mecanica
Test making the changes manually; this is starting in 1st, then 2nd, 3rd and direct or over drive.
If manually the engine is also accelerated and the vehicle does not advance, you have (discs) or burned pastes of that change.
He claims not to put the reverse change (R), because transmission is damaged.
