Seat Toledo 1.8 Monopunto.Falla The Start in Fri
17 years 1 month before #5401 by manual-mecanica
I have a Seat Toledo 1.8 with monopunto injection and the cold starting regulator fails, the valbule works well but I need to know that the command, thanks
17 years 1 month before #5403 by manual-mecanica
Manual-Mecanica Answer on the Re: Seat Toledo 1.8 Monopunto.
RP engine, MONO-JETIRONIC BOSCH INJECTION SYSTEM, catalyzed.
The first of all is to look if you have any memorized fault code, for this you have to go to the fuse box that is on the left of the pedals. There must be a black-yellow cable with a black terminal, this cable is under the fuses.
In that terminal you have to plug a cable with a switch so that when you press the dough circuit, you also have to put in the cable that connects the switch and the black terminal a LED diode connected to a positive battery.
To access fault codes:
1º Remove the contact, then connect the cable with the switch to the diagnostic terminal.
2º Connect the LED diode between the battery positive and the test cable.
3rd start the engine and leave it slowed down (if I didn't start, turn for six seconds) and leave the contact on
4th Press and hold the test cable switch for at least 5 seconds and then release.
5th The LED diode will begin to flash repetitively. (The fault code consists of four figures ranging from 0 to 4. Each figure is represented by short impulses in a row, between figure and figure there is a small pause and between code there is a long and a half second pause.
17 years 1 month before - 17 years 1 month before #5404 by manual-mecanica
This is the electrical scheme to make the diagnostic cable
Last edition: 17 years 1 month before by .
17 years 1 month before #5405 by manual-mecanica
And this is the way in which a fault code is seen
17 years 1 month before #5406 by manual-mecanica
FAIR CODES:
1111: Failure module failure,
deletion of the fault:
replace it
1232: Butterfly actuator failure, control unit failure,
deletion of the breakdown:
check wiring, connections and butterfly actuator, replace butterfly actuator, replace control unit
2121: slowdown switch,
elimination of the breakdown:
Check wiring, wiring connections, connections On and switch, replace defective or mismatch switch, replace ignition point control valve.
2122: There is no RPM signal,
fault elimination:
check wiring and connections, replace Electronic TSZ-H ignition module or Hall impulse generator.
2212: Failure in gase butterfly potentiometer,
check wiring, connections and potentiometer, replacement of the potentiometer of the gas butterfly.
2312: Motor temperature probe failure,
fault removal:
Check wiring, connections and motor temperature probe, engine temperature probe substitution.
2322: Probe failure Admission air temperature,
Check wiring, connections and probe Admission air temperature, replacement of the admission air temperature probe.
2341: Lambda regulation failure, (values ​​above normal),
elimination of the fault:
check the stagnation of the admission collector, undue air shots, broken vacuum hoses, etc. Check the ignition point and the state of spark plugs, high cables, distributor lid etc., check the fuel feed pressure (between 0.8 and 1.2 bar). Check that the injector is not open or drip. Check compression in the engine (possible lack of compression) Check Lambda probe wiring and connections, and if no other cause is found, replace Lambda probe for being deteriorated or aged.
2342: Lambda regulation failure, (values ​​below normal),
check the staging of the exhaust collector, check the probe wiring the connections, and if no other reason is found, replace the Lambda probe.
2343: Lambda regulation failure, (sporadic fault and probe in order of use),
proceed as in 2341.
4431: Butterfly actuator failure,
check the wiring the connections, and the actuator, replace if necessary.
4444: No fault was found:
all systems in order.
0000: End of the code sequence or codes.
Once the repairs have been carried out, disconnect the battery or the engine control module connector for at least 30 seconds to erase the fault codes and registered Lambda control codes. Then perform a road test so that the control module can learn the basic values ​​and record new failures if any.
