ELECTRICAL INTALATION
17 years 3 weeks before #5386 by manual-mecanica
ELECTRICAL INTALATION PUBLISHED BY MANUAL-MANICA
Hello I have a Citroen Xsara, my problem is that when I go by road the lights lights the position, the problem that you want. I hope someone can there, thank you
17 years 3 weeks before #5391 by manual-mecanica
Manual-Mecanica Response on the Re: Electrical INTALATION
These cars give problems with the steering wheel command before changing anything disconnect and try it and if they do not turn on it is the command if they are lit and you have to prove what is lying or some relays although I do not believe.
17 years 3 weeks before #5398 by manual-mecanica
Hello grcias for the fast answer I will try it to open if it is the command of the bowling. Someone knows where I can download the Citroen Xsara 2 workshop, thanks
