Fiat Stilo Bizona Climatizer
17 years 1 month before #5163 by manual-mecanica
Bizona Fiat Stilo Climatizer Published by Manual-Mecanica
The air conditioner fails me, only the co -pilot side works, on the driver's part it only casts cold air, someone can tell me what it can be, it is also heard as a motorcillo constantly. Thank you
17 years 1 month before #5195 by manual-mecanica
Manual-Mecanica Answer on the Re: Bizona Fiat Stilo Climatizer
Normally this system can be done with electronic worthy, but they can be several things: the step -by -step motor Yasi can give yourself an idea.-
14 years 1 month before #26938 by manual-mecanica
The same problem had in the driver part did not come out hot air only cold on the copiloto worked well everything I sounded a little a motor below the HODIDO Motorcotus that opens the Hot Air to Frio and reversary tramp. With white teeth then it is the first one below you take out with a tubular wash of 5.5 a little picked up but it comes out and you see a white lever you can move with your hand the lever and see that hot air enters. I put some photos with the fucking engine.
