Dor 2002 Pointer console warming
17 years 1 month before #5162 by manual-mecanica
Heating the 2002 Pointer console published by Manual-Mecanica
I have a 2002 Pointer for 3 years, the console where the speed lever is, no longer has a converter is heated, and it has all its hoppers but still the heat goes up a lot, someone mentions me that they were the hoses of the heating but then I do not know if they reach there, does anyone know what happens with this? thank you
17 years 1 month before #5173 by manual-mecanica
Manual-Mecanica Response on the Re: Heating of the 2002 Pointer console
The exhaust line passes through the tunnel between the seats? It can be sympleously that, that is not well isolated thermally and upload the heat of the escape.
Moreover, it is possible that the catalyst is half clogged or beaten and hot much more than normal.
In any case, there is only one way to check what is heated and why, you make a more or less long journey and when you start noticing the heat in the tunnel, you return home or where you can lift the car and get underneath.
It goes without saying that you are careful what you do that is underneath is you (secure the cat or blur, firm and horizontal soil and others). Once you are underneath, the heat that radiates the pieces will give you what is happening. Anyway, the hand to the gearbox closer, if you do not notice heat, it is the exhaust line and especially the catalyst that is radiating the heat.
All the best.
17 years 1 month before #5193 by manual-mecanica
The car has dropped to you with power when the catalyst is beaten or half clogged normal me the car loses power, what I would do is first see that it is what happens under the car and then evaluate what to do or not.
