I have a problem in Nissan Sentra Motor QR-25
17 years 1 month before #5129 by manual-mecanica
I have a problem in Nissan Sentra Motor QR-25 published by Manual-Mecanica
The vehicle arrived at my workshop in crane overhered it, it turns out that I turned on the engine before disarming it and turned on, disguised and spotted the butt brushed her in the industrial workshop and everything alio well until there. I give to the key of the key but there is cut, if someone has had the same problem that helps me my email is I will thank you
17 years 1 month before #5138 by manual-mecanica
You have problems with the crankshaft angular position captters and the camshaft phase collector (if I have not sure that I am not sure).
The switchboard gives the first spark as soon as I started, but since it does not know where the engine is going what the cylinder is the spark jump because diréctively does not cause any spark jump. Check the connectors and the sensors themselves, it will not be that someone is out of place or full of shit.
Greetings and I hope it is that.
17 years 1 month before #5142 by manual-mecanica
Hello TMB it may be that the immobilisator is activated controls on the board if any light flashes or you will have to put a scanner to verify that greetings
17 years 1 month before #5198 by manual-mecanica
Check the wiring, you left some disconnected cable or invest some connector.
