Daewoo Lanos Problem 1.4 Year 2002
16 years 11 months before #5115 by manual-mecanica
DAEWOO LANOS PROBLEM 1.4 YEAR 2002 PUBLISHED BY MANUAL-MECANICA
Good morning
to see if someone can help me, because we have no idea where the failure is.
I have a Daewoo Lanos 1.4 of the year 2002 and for two weeks, when I start the car and circulate a while with it, stop, and we have discovered that a fuse is based (the electrical system of the gas pump, I think). When we change it for a new one, it normally starts and circulate another little while with him, until the same thing happens.
The mechanic has checked the pump and wiring in case there was a short circuit, but all ok.
Now I have it again in the workshop and the mechanic has no idea, he needs to review the food system, but it is not very clear.
If anyone knows what can happen to him, he would help me a lot, because I am more lost than an octopus in a garage.
Many thanks for everything.
16 years 11 months before #5121 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Daewoo Lanos 1.4 Year 2002
Hello, look is not a short circuit because the fuse does not cut immediately, you have to fix that another system feeds that fuse, they are almost never only for the pump, now when discovering this other system check if it also has a relay, there are pumps that in addition to the fuse are commanded by a relay, when these relay do not work correctly, they produce an overheating in the system, with a possible short That this is the problem, the toyatas occupy this type of system, check the other converters.
Well, your symptom is not short sirw with overheating,
16 years 11 months before #5123 by manual-mecanica
Change the gasoline pump that is the problem when heating the pump is put into circuit and burns the fuse on high consumption of the same and tube that problem.
16 years 11 months before #5128 by manual-mecanica
From what you say I think it is because the gasoline pump must be obstructed or the gasoline filter, and it costs it to turn, that leads to an excess of electricity consumption of the pump that causes the fuse to burn. Anyway, check the entire gas feeding circuit. greetings
16 years 11 months before #5155 by manual-mecanica
The first thing is the gasoline filter in these cases is it the cheapest does how much we do not change it?
