Cancel Turbocompressor in Fiat Siena TD HL
17 years 1 month before #5154 by manual-mecanica
Manual-Mecanica Answer on the Re: Cancel Turbocompressor in Fiat Siena TD HL
You can disconnect the hose that goes from the turbocharger to the admission easily to reach the workshop without using the cylinders that is very dangerous. Temporalmete you can do it.
17 years 1 month before #5197 by manual-mecanica
The problem is not the oil that will go to the cylinders since it would burn the engine, but you are going to fill the entire oil exhaust system, to this point it sees how much it costs to repair the turbo or see a scrap and buy one, but if you take away the oil pass you will end up blocking the turbo and you will break the fins of the same and the damage will be worse since you can pass you to the same aspiration.
