TWINGGO ACCOUNTAKILOMETERS
17 years 1 month before #5008 by manual-mecanica
TWINGGO ACCOUNCHILOMETERS PUBLISHED BY MANUAL-MECANICA
Hello everyone,
could they please help me? I have a problem with
Twingo's accountckilometers. It works randomly (I can do 6 km, or 500 meters, and then stay to zero, and work again when you want).
I would like to know how it works and from where it is repaired, since I have read the workshop manual several times and I find nothing on the subject.
Do you think it is easy to rise it or would it be better to take it to the workshop?
Thanks for your time.
17 years 1 month before #5012 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Twingo Account
Hello, I had this same fault and I could repair it very easily, it was in a lagoon but I imagine it is the same problem. You may have to change the speed collector that goes in the gearbox, in the workshop 8 on PAG17 it comes as the collector I think the price is about € 35 and the repair is 5min. On the Twingo I do not know how to go mounted, I imagine that with 2 screws in the lagoon only goes with a pin, to know where you can look in manual 2 on page22, you just have to remove in connector from the 3 cables and pull the collector up but first see if it carries screws, pin or does not wear anything.
I hope it helps you.
Greetings
