Audi A3 start
17 years 1 month before #4873 by manual-mecanica
Audi A3 starter published by Manual-Mecanica
I have starting problems in an Audi A3, when the engine is hot and I stop it, trying to start it again it costs it enough to start.
Has anyone had this problem and could help me?
Thanks in advance.
17 years 1 month before #4891 by manual-mecanica
Manual-Mecanica Response on the Re: Audi A3 Start
Czech the engine temperature sensor reading, the sensor is damaged and sends a -40 ° C reading, and this makes it a long time to start. Checalo with Scanner not reading the board
17 years 1 month before #4961 by manual-mecanica
For me you have a problem in the Conbustible withholding valve or the gasoline pump that does not have the necessary half kilo less in the pump it already has a hard time starting the car.
greetings........
