Ignition problems in Fiat Siena 1.6
17 years 1 month before #4886 by manual-mecanica
Manual-Mecanica Response on the Re: Ignition problems in Fiat Siena 1.6
hello again. I tell you that if you have a pulse in the injector it means that the sensor that told you works since it cuts both the spark and the injection. You must have the problem in the coil or module.
17 years 1 month before #4888 by manual-mecanica
Place all the electrical components of a similar car, captor, coils, relay, computer, rifle, alternator; That is, use all the compounds that are attached to the car front branch of the car. That is the strange thing!
17 years 1 month before #4893 by manual-mecanica
The cable branch too?
17 years 1 month before #4909 by manual-mecanica
That is the only thing I need to change, but I leave it as last option!
17 years 1 month before #5021 by manual-mecanica
I thank you for all the advice you sent to me friend! The car is already underway, it seems that there was a short one inside the cable branch, I change it and start, now I only have to check the lack of acceleration, since it seems like drowning at approximately 3,000 laps. a hug
