Ignition problems in Fiat Siena 1.6
17 years 1 month before #5022 by manual-mecanica
Manual-Mecanica Response on the Re: Ignition problems in Fiat Siena 1.6
I thank you for all the advice you sent to me friend! The car is already underway, it seems that there was a short one inside the cable branch, I change it and start, now I only have to check the lack of acceleration, since it seems like drowning at approximately 3,000 laps. a hug
17 years 1 month before #5026 by manual-mecanica
Friend, fix the captor cable in the distributor, this can be short and does not let the spark pass, I spend the goal 04 Iny. Once solved if that is disconnected by the battery for at least 3 hours, so that the computer is reset.
17 years 1 month before #5041 by manual-mecanica
I am glad that you already have it, look if you get a scanner to see what fails you jump into the memory of the ECU. Check the fuel pressure, it does not have to be more than 1 bar and test the MAP and take out a spark plug and look what color is, test the Lambda probe if it works.
17 years 1 month before #5174 by manual-mecanica
Hello, I have a problem, the failure of the injection problem is turned on and I have cut a spark plug cable to be that what m marc?
17 years 1 month before #5184 by manual-mecanica
How do you have a spark plug cable? Is it working in three cylinders?
