Cluch noise in Neon 00
17 years 2 months before #4801 by manual-mecanica
Cluch noise in Neon 00 published by Manual-Mecanica
Greetings to everyone
I have a problem with a 2000 Neon (standard) which makes the box like a blender and when the clutch pedal is removed, after a while no longer does it but in times he does again and only by standing and maintaining the
clutch pedal
17 years 2 months before #4820 by manual-mecanica
Manual-Mecanica Answer on the Re: Cluch noise in Neon 00
You have the clutch collar bearing about to disintegrate by wear.
The repair involves disassembling the vehicle gearbox and once separated from the engine, access the clutch or cluch and replace it with a new one.
There are \ "repair kits that consist of disk, mace and clutch collar. Since it is rarely advisable to change a single piece of the set and leave the old mounted.
The price of the clutch kit is not expensive, the worst is labor since removing the gearbox is a task that takes many hours of labor.
All the best.
