Kon transmission problem
17 years 3 weeks before #4727 by manual-mecanica
Kon Transmission Problem Published by Manual-Mecanica
I have a Ford Windstar 95, I put kambio and go out it is reverse or Kualkier Kambio goes out and they do not enkuent the fault please someone k me of a response of what k can be.
THANK YOU:(
17 years 3 weeks before #4734 by manual-mecanica
Manual-Mecanica Response on the Re: Kon Transmission Problem
Most likely, you have no problem in the box, the problem must be in the injection or rather in the idle valve if it were not there, you fix if all the engine cylinders work for you the problem can be strength.: P
17 years 3 weeks before #4735 by manual-mecanica
Thank you for the answer
but I do not understand ak injection do you mean and the valve where is kmo can know if that is what does it work ??
I will grab you very hung by K they don't know how
17 years 3 weeks before #4746 by manual-mecanica
The idle valve is located between the engine and the air filter, following the tube where the engine aspires the air, you will find the gas butterfly and the idle valve.
If you are not seasoned in the issue of mechanics, it is best to take the car to a workshop.
Another thing that you can have bad is that you have a ignition failure in a cylinder, as the partner says, or the engine with excessively low idle, or that the converter carries an oil that is not adequate and that is why it makes the engine heating when putting a speed.
I have several questions:
if you accelerate a little, the windstar comes out or do you also stop speeding? And if you accelerate in the dead man, it fails and tends to stop? or on the contrary it accelerates without problems?
Greetings and what is you tell me ok?
17 years 2 weeks before #4766 by manual-mecanica
I forgot, I turned on the key well but I had a k pner a dierctoa cable wing to k pledge ...
it works well in parking and when I change it, it turns off
