318 motor valves
2 years 3 months before #54451 by manual-mecanica
318 motor valves published by Manual-Mecanica
Hello everyone.
It turns out that I ask for the 318 motor valves that I am repairing and they tell me that they come in different measures +3, +5, +15, etc.
And stay in Chock, first see that I listen to that. Could someone help me where is that measure that refers to?
Thank you.
2 years 2 months before - 2 years 2 months before #54452 By manual-workshop
Manual-workshop response on the engine Valves for 318 Motor
318 motor valves may have different measures that indicate the overmedy of the valve, that is, the increase in the diameter of the valve head to compensate for valve seat wear. To know the measurement of the valves of your engine, you must measure the diameter of the valve head with a caliber and compare it with the original diameter. For example, if the original diameter of the intake valve is 48,665 mm and the measured diameter is 48,815 mm, the valve measurement is +15
1 year 6 months before - 1 year 6 months before #54492 by manual-mecanica
Manual-Mecanica response on the engine Valves for 318 Motor
, the measure that they are mentioning probably refers to the size of the valve in millimeters in relation to the cylinder diameter. In general, when talking about measures such as +3, +5, +15, etc. It means that the valve is slightly larger than the standard diameter of the cylinder. This can affect engine compression and performance, so it is important to choose the correct measure to guarantee a good operation.
hydrotherm-bombasyplantasvenezuela.com.ve/index.html
