Doubt about rings in piston
3 years 4 months before #54355 by manual-mecanica
Doubt about rings in piston posted by Manual-Mecanica
Good morning, I was recently maintaining my diesel engine because I had the loss of power and threw the oil through the rod, indicating decompression in the engine, so I decided to change the pistons and rings respectively.
I have put it again and continue giving me the same problem, I have tried two different brands of rings and pistons in this order
first assembly: New Teikin pistons, TP rings
- again gave the initial problems, it was decided to change the rings brand (appearance of recent failures, 100km approx)
second assembly: the same Teikin pistons, Npr Rings
- Rings Npr - Occasion, the turner said it could be a factory failure in the pistons (after the settlement of the rings appeared)
Third assembly: pistons were changed to some of Alfin coating (Teikin equally), TP rings
again gave again that problem of the oil, I am that I go crazy with this engine and the truth is that I want to know what would be their opinion about the true failure, the suppliers and the mechanic Without problems, others say that this behavior is completely normal for the oil rod, others say it can be a failure in the measurements of the rings sought and others say that it can be a second failed lot
attached photos of the third assembly
3 years 3 months before #54367 by manual-mecanica
Manual-Mecanica Response on the subject Doubt about rings in piston
Hi Kevin, the gas output tube or system in the valve cover is clear, because if this obstructed gives you that problem by not having how to dissipate increasing the internal pressure of the gases and looking for exit by the rod
