Work crankshaft partner 1.6 HDI dv6 8 valves
5 years 1 month before #54139 by manual-mecanica
Hello everyone. My name is Mauricio and I would like to consult them if someone knows how the crankshaft of the partner motor 1.6 HDI dv6 8 valves. For example, Peugeot 307 2.0 HDI has a hole near the starter engine to lock the crankshaft. I wanted to know if the 1.6 HDI engine of the partner has something similar.
I already appreciate the answer.
All the best.
Mauricio
5 years 1 week before #54145 by manual-mecanica
Manual-Mecanica response on the topic lock partner motor 1.6 HDI dv6 8 valves
Good, I think that the crankshaft pinion has a round hole of 5mm that coincides at the top with another of the motor block but you must be careful not to force the pinion with the useful place since the sheet is easily folded and the figger of the crankshaft reads information of that pinion.
