HLIux 3.0 D4D 2010 does not turn on motor
5 years 9 months before #54027 by manual-mecanica
HLIux 3.0 D4D 2010 does not turn on the engine published by Manual-Mecanica
Hello people, how are you? I have a problem with a Hilux 3.
0 D4D 2010 starts only if I act on the gasoil filter bombin after it starts it is very well not presenting failures when connecting scanner, the injectors were checked in bank and they are fine, they do it at all times know if it carries electric pump in the tank? The filter is new and original or if they have gone through this experience greetings to all
5 years 9 months before #54029 by manual-mecanica
Manual-Mecanica Response on the Hliiux 3.0 D4D 2010
Hello, apparently the transfer or low pressure circuit is emptied, you have to change the gasoil filter portfilter where the barley bombin goes.
