Fiat Ducato 2.0 JTD of 115cv year 2014
6 years 1 month before #53876 by manual-mecanica
Fiat Ducato 2.0 JTD of 115cv year 2014 published by Manual-Mecanica
Good to all, I have a problem with a 115CV 2.0 JTD fiat ducato, the vehicle was doing well but suddenly it does not start, it has stopped for a month. I put the machine and do not fail, I check the fuel pressure and motor revolutions and do mark. The fuel pressure reaches me up to 700 press. I think that injectors may be wrong, someone has happened to someone or has an idea of ​​what can happen. Thanks in advance.
6 years 3 weeks before #53906 by manual-mecanica
Manual-Mecanica Response on the FIAT DUCATO 2.0 JTD 115CV year 2014
Hello good day ... so that a vehicle does not start is due to many conditions in general but the main thing is fuel, air and spark. You must find the failure based on those 3 main standards (in case the engine has not been repaired, discarding distribution time, compression, among others), since you have reviewed the fuel and pressure system, verifies the state of the spark plug Start and engine.
6 years 2 weeks before #53908 by manual-mecanica
Try with self -ranks in case they had hit the injectors, a greeting.
