Problem after lowering cylinder head
6 years 6 months before #53744 by manual-mecanica
problem after lowering a cylinder head by manual-mecanica
Greetings to everyone I have a Hyundai Santa Fe Crdi, the time girdle was
broken everything and now that I went to start it does not start and I do not know if there is an electronic problem or some mechanical failure verifies everything and nothing starts I would appreciate their help if anyone knows of the motors since I am on the edge of madness ... greetings greetings ...
6 years 5 months before #53766 by manual-mecanica
Manual-Mecanica response on the problem problem after lowering cylinder head
Hi Mecmoch.
Check that when you put the belt the piston one in work time, remember that in four -stroke engines the pistons are synchronous two by two, therefore because of an oversight it could be that you would synchronize with the escape time
6 years 5 months before #53769 by manual-mecanica
In addition to reviewing the set as the fellow servilimit tells you, to look that the taques, which I suppose that they will be hydraulic, have not been "full" when riding, leaving valves footprints and leaving it without compression (to see if the escape smells), this happened to me in his day and there was no way to start it and after a day of attempts I started ...
6 years 4 months before #53792 by manual-mecanica
Thanks for your help ... We already made it walk the taques empty them before riding everything at the end the crankshaft sensor was damaged and we forced her to walk with Ether ... hahahahahaha after starting it on the light of Check Engine
6 years 4 months before #53793 by manual-mecanica
