Ford escape, distribution kit
7 years 2 months before #53406 by manual-mecanica
Ford Escape, distribution kit published by Manual-Mecanica
Hello everyone!
I have a 2007 Ford Escape which was spent time, damage the valves and other engine things, all solved, but the time chain kit is not found anywhere, it carries two identical pinions and an 87 link chain, on eBay I have seen hundreds but or only bring a pinion or the chains are short I know what to replace the pieces.
any suggestion would be appreciated
7 years 2 months before #53410 by manual-mecanica
Manual-Mecanica response on the Ford Escape theme, distribution kit
Locate the spare parts for Ford Duratec 2.3 engine. You probably do not find it on eBay since in the US the Duratec is marketed with a single camshaft, your vehicle must be armed in Vietnam or by those latitudes. In which place you are, and the concessionary Ford what tells you?
