Verna 2004, Hyundai, when heating he sounds a lot, like noise of divers, new oil?
7 years 5 months before #53224 by manual-mecanica
Hello, Hyundai Verna (Accent) 2004, a tree cams, 12 valves, when the engine is heated, it begins to sound a lot, as hydraulic divers, but it has power, it is economical, it works very well, but it makes a lot of noise, it is added additive remurs and new oil, asks all these models sound? Is any factory defect? Any partner already found the fault? Share, thanks
7 years 4 months before #53244 by manual-mecanica
What about the oil pressure when the engine sounds?
It is not normal to sound ...
7 years 4 months before #53272 by manual-mecanica
Hello.
Regarding the engine noise, I tell you that the same thing happened to me with a Samurai Suzuki. The problem was the camshaft, it had a wear that when the engine started it had a normal sound but when the engine was heated, a noise appeared like valve pounding.
The solution was to rectify the camshaft.
