Change Peugeot Motor, Put Tu5JP 1.6 on partner 1.4 Tu3JP
7 years 9 months before #52995 by manual-mecanica
Good morning someone made the engine change of a 1.4 partner and put a 1.6 TU5JP, physically from the crankcase to the block they are visually identical. I wanted to know that if I can adapt this engine and that I should modify. GREETINGS
7 years 5 months before #53220 by manual-mecanica
Hello, did you have any response to this? I am in the same as you
thank you
