Problems with 4x4 from a Terracan 2003
8 years 1 month before #52704 by manual-mecanica
Problems with 4x4 of a 2003 Terracan published by Manual-Mecanica
Dear friends: I have problems with a Terracan, at first I did not connect the double, I checked the vacuum solenoid system, but when the spikes disconnect to check the current, the 2 4x4 lights were lit and they no longer went out, the diaphragm of the front differential is fine works with direct suction the engine of the equator in the transfer also works.
