VW Transporter 2.4 Diesel does not start
8 years 8 months before #52094 by manual-mecanica
VW Transporter 2.4 Diesel does not start published by Manual-Mecanica
Hi, I have a VW Transporter 2.4 Diesel to which a botator was broken. To which the lid is taken away and the broken bad is changed. When putting it I can't turn it on. I already check the tuning of the distribution and the pump, look at the heating, the air filter and the battery, everything seems normal. The engine rotates quickly but does not turn on help please
8 years 8 months before #52106 by manual-mecanica
Manual-Mecanica response on the VW Transporter 2.4 Diesel theme does not start
Check by taking the engine compression is likely that there is some crooked valve or other crooked valves. Discuss that there is hermeticity in the valves, there may be low compression in the cylinders or with the compressimeter discard that first.
8 years 8 months before #52121 by manual-mecanica
If it is fine with compression, and the distribution well left, it has to tear you away .. Pacicity to purge the injectors at the start ... It takes time sometimes for a while.
8 years 8 months before #52141 by manual-mecanica
What system is it, I have not seen but is it a conventional electronic system? Cr?
