NEON 95 Failure Failure
8 years 9 months before #52065 by manual-mecanica
NEON 95 Failure Failure Published by Manual-Mecanica
Good day.
I have a 95 neon that turns on the fans at a very high temperature.
I already put thermostat and new temperature sensor.
It also marks me fails in oxygen sensor but I don't think that is why between the fan at the wrong time.
Thank you.
8 years 9 months before #52066 by manual-mecanica
Manual-Mecanica response on the need Neon 95 Failure Failure
hello. Fans turn on at an app temperature of 95 to 98 degrees at the first speed and around 105 degrees the second speed is normal. Because you say they turn at a very high temperature. How do you know?
8 years 9 months before #52067 by manual-mecanica
Fans are activated when the AUJA reaches up to 3 rooms and sometimes the heating alarm sounds.
If I go on the road, the thermostat keeps the temperature, in half, but when I go in the traffic it rises to three quarters for fans to enter.
Thanks for answering.
