Ford index failure
8 years 10 months before - 8 years 10 months before #51967 by manual-mecanica
Ford index failure published by Manual-Mecanica
Hello everyone is that my Ford has been in the official workshop
where I do all the reviews of my 2008 motorhome
with 70,000km the turbo was disconnected ..? And they ran out of force
I changed the turbo I went for her the case is that I could
not even leave the workshop I did not have to leave it they call me that it is repaired after paying the workforce because they had sent him badly the turbo left the workshop
and I walk about 75km and puff stopped the turbo ..? I stay without force
since then I have been called 6
months .
Latest edition: 8 years 10 months before by .
8 years 10 months before #51968 by manual-mecanica
Manual-Mecanica Response on the IMDEGENABLE FAILURE
Have you not reported the workshop ???
If you have paid to fix or return your money.
Then take it to another workshop
8 years 9 months before #51975 by manual-mecanica
If I told them that and what they answered was that they did not hinder them
and do not want to return the money the case that changed the turbo
and do not burn the case is that when they changed the turbo
workshop and
it is worse that with the old turbo I did not walk the mechanic the mechanic . Again I already leave the 76 km, I stopped the contact
and walking in TSM spent about 15 minutes I try and everything ok
Jo was repaired alone .. The case is that the same day the same conclusion happened again when the turbo disconnects and when it cools it again and almost 7 I do not find the workshop and does not find the breakdown. Thanks friends
8 years 9 months before #51977 by manual-mecanica
Hi Pacoexpert ", as the partner says; denunciales because they are charging you for a job that they do not" know how The turbo, the empty tubes that go to this, if the flow rate or the CKP collector or a bad electrical contact that takes it as an emergency mode is evil ... all that would have to look at it by doing it a scann before changing anything ... it is what gives me to think, if it is not from turbo, that they return the money and put the one that you brought before; These people.
8 years 9 months before #52020 by manual-mecanica
Hello, what a model is the vehicle and if you can take a picture of the engine to see what the type is and look what brand is the turbo greetings
