TPS Bravo sensor problem.
8 years 10 months before #51905 by manual-mecanica
TPS Bravo sensor problem. Posted by manual-mecanica
Hi Foros, it happens that my Fiat Bravo 1.6 16V 2000 mechanic, benzina, every time it is ranging as braking and the speed increases apoco, connect my scanner and throw the failure P0120 TPS sensor, short circuit to B+. Senal this OK and the 3 cable that is land gives the right thing. I would like to know what are the steps to follow when it is a short circuit? What should I check ,,, how to know if it is failure of ECU ,,,, (the car starts without problems, the TPS sensor and MAP sensor change without result)
all kinds of help are appreciated, see you soon.
8 years 10 months before #51909 by manual-mecanica
Manual-Mecanica response on the problem with a fiat bravo sensor.
Hello, how do you have to control that the return signal cable to the ECU is not cut if it is not so and you already changed the sensor the fault is the ECU and that if it is repaired greetings
