Automatic Climateizer Peugeot 308
9 years 2 months before #51590 by manual-mecanica
PEUGEOT 308 automatic air conditioner published by Manual-Mecanica
The automatic air conditioner of my 308 (adjusted between 21 and 22ºC), when it makes an external temperature exceeding 30º Celsius, after a period of time of functioning normally stops working. As if the gas compressor disconnected. Refrigerant gas pressure is correct. Turning off the team for a period of time and turning again works but for a short time repeating the failure. This does this in automatic or manual mode.
With lower temperatures the problem does not manifest.
8 years 9 months before #51997 by manual-mecanica
Manual-Mecanica response on the automatic air conditioning theme Peugeot 308
Hello Ghostider.
The lack of your 308 I don't know what it can be.
If you want we can buy the 308 manual among which we have a 308 forum and put it scanned in the manuals maybe in the manual puts what is the defect of your car.
All the best.
8 years 9 months before #52014 by manual-mecanica
Hello, the connection and disconnection of the A/C may be due to several reasons ... internal of the automatic or external climate control module. The disconnection may even be due to the fact that the engine temperature rises more than recommended ... in this case the motor controller sends a request for air disconnection to the communication network of your car ... It may also be due to an electrical problem in the compressor material. To solve the problem in my opinion you should make a good diagnosis to the electronic control of the modules involved. Sur and sl2
8 years 9 months before #52018 by manual-mecanica
Hello, control that the precion of refrigerant gas is the correct there can be the problem.
8 years 8 months before #52088 by manual-mecanica
Check that the fan 1 and 2 speed works. It is very possible that the 1st does not work
