FÍAT 600
9 years 3 months before #51493 by manual-mecanica
FÍAT 600 Published by Manual-Mecanica
Hello people, good morning, I have a 600 fíat standing with the 0km engine and I fear that my pistons were hit for lack of use, could I advise me what I can do to prevent it from breaking and being able to take it off? Thank you very much!
9 years 2 months before #51519 by manual-mecanica
Manual-Mecanica Answer on the Fíat 600
Remove the spark plugs and add it for the pistons holes about five centimeters of a thin lubricant, it can be diesel or even fluid of transmissions, then if not attached, turn the engine, without placing the spark plugs, until the aggregate lubricant is expelled by the exhaust valves and the holes of the spark plugs, then place the spark plugs again, the cylinders will be lubricated. If the engine is not used, you should perform process with any frequency. If you turn on the engine, do not be scared by the smoke that will come out of the escape, soon it will disappear.
Luck.
9 years 2 months before #51520 by manual-mecanica
If the engine was already stuck, you do the same but with a solvent like the thiner mixed with oil and leave it from one day to another, then try to turn it by hand, without forcing it, in both senses until you notice that it takes off.
You will tell me
