P0100 Opel Signum 2.8T V6 OPC failure
9 years 3 months before #51455 by manual-mecanica
P0100 Opel Signum 2.8T V6 OPC Published by Manual-Mecanica
Good morning to see if someone makes me a hand or among all we solve them.
I am a mechanic of weekends by Hobby and my car is presenting the P0100 fault and is in clean mode or emergency mode or as it is said but does not rise from the 3000rpm. The engine is a Z28NET (in case anyone has digrams)
I tell you the story and what I have done:
I went to a workshop to connect the computer to the car because the car with the English key on the board was turned on and did not take off, the P0100 code came out. They erased him and came to the house but remained the same without climbing 3000rpm.
I cleaned the flow and check the connections, also probate with the voltimeter and sent me the signal well, turned on the car and did the test of trying to pass from 3000 rpm and I could not, when trying to arrive, the car comes out with the key and when lowering rpm it is removed.
scan and leave pending P0100.
I ask me for a new flow install and remain the same.
I review and change the emptiness lines that are in sight. I try again and do not rise from the 3000 rpm and the error comes out.
Also clean the admission butterfly and nothing.
Anyway, I know where to get most and as I have no diagrams I don't know if there are more emptiness lines or where to get most to solve.
P.S. Sensations: The car turns on normal, without minimal fluctuations or failure, 2000rpm and rises normal until 3000 that is where the failure is pressed and does not rise anymore, when trying to pass them it begins to make black smoke by the exhaust (gasoline without burning) and does not upload the pressure of the turbo I imagine due to the emergency mode or clean mode.
Well I hope not to make them crazier than I am looking for the fault! ... Thank you !!!!!
