Jeep Korando 2002 Diesel
9 years 6 months before #51120 by manual-mecanica
Jeep Korando 2002 Diesel published by Manual-Mecanica
When it is in idle the engine gets irregular causing the entire vehicle to move at that rhythm, but it is enough that the revolutions 50 rpm more disappear immediately the irregularity.
My question is: Is there any way to adjust to increase the idle speed?
9 years 6 months before #51121 by manual-mecanica
Manual-Mecanica Answer on the subject Jeep Korando 2002 Diesel
Good afternoon, you must work between 900 and 1000 rpm and to accelerate it has a screw on the fuel pump where it stops, adjusting that screw has to lift the safe march. I hope it helps you
9 years 6 months before #51122 by manual-mecanica
Thanks I'm going to try and tell you
