Problem with change from ECU of a Nisan Tida 2012
9 years 7 months before #51059 by manual-mecanica
The problem is to change the ECU of a Nisan tida keeping the antenna and ancient keys. But when I want to program keys it appears that the code is not correct so I can no longer program. Revise Error codes and I appear code Error P1610 Blocked
9 years 7 months before #51060 by manual-mecanica
Manual-Mecanica Response on the problem with a change of ECU of a Nisan Tida 2012
Hello to be able to unbelieve the immobilizer disconnect the battery at least 30 minutes after that it will unblocate and the key can be programmed
9 years 6 months before #51063 by manual-mecanica
send me the chassis number
