MINIMUM DOWN STEP THE BRAKE
9 years 8 months before #50922 by manual-mecanica
MINIMO LOVE WHEN PORMED THE BRAKE PUBLISHED BY MANUAL-MECANICA
Greetings to all, I have a Mazda protects 98 engine 1500, the problem I have is that when you step on the brake the minimum is lowered almost until the engine is turned off, already clean and check the IAC valve and this perfertion, also completely clean the acceleration system and the continuous problem does not know what it may be.
9 years 8 months before #50925 by manual-mecanica
Manual-Mecanica response on the minimum theme when the brake
Hello, your problem is likely to be in the brake on the serb
