Twingo who stops
17 years 3 months before #4420 by manual-mecanica
Twingo that stops by manual-mecanica
Hello everyone. I go to the forum to see if someone can throw me a cable with a Twingo that is giving me headaches. The situation is as follows, it is a Twingo 1.2 8 valves with multipunto injection, it has about 50,000kms and in general it is going quite well, unless when you feel like it is stopped being in idle and then it is difficult for it to start. The idle valve is already discarded and no matter how laps I have given you nothing, I would appreciate some idea. All the best
17 years 3 months before #4426 by manual-mecanica
Manual-mecanica response on the re: twingo theme that stands
Have you proven gasoline pressure? Do you have to have it between 2.5 - 3 bar.
Have you proven the feeds of the unit? Check that there is no tension drop and above all the masses.
Have you checked the spark plugs? If they are not of the same thermal degree they cause parasites that block the unit and stop the car.
You already have several ideas.
All the best.
17 years 3 months before #4432 by manual-mecanica
Thanks in advance. The spark plugs is looking, the other two options I will see if I look at it and tell you, a greeting
17 years 3 months before #4445 by manual-mecanica
Hello golf, these cars carry a turning sensor on the ambio that looks like a plane you will see and it is easy to change normally give these problems, it carries only one connector and two screws is at the top attached between the engine and the change
17 years 2 months before #4475 by manual-mecanica
We will try to see ... thanks for the suggestion.
