ELECTRIC FAILURE RENAULT LAGUNA II
9 years 9 months before #50814 by manual-mecanica
ELECTRICA RENAULT LAGUNA II FAILURE PUBLISHED BY MANUAL-MECANICA
Good, see if you can throw a cable with this matter, it turns out that I have a Renault Laguna II of the year 2007 Motor F9Q with boot card, the case is that the car went to start one day and not start, it is investigated and discovered that the FM20 fuse of 60 amps of the vain engine melts, it melts as soon as the contact is launched after 2 seconds Fuse of 60, common consumers such as fans, air conditioning compressor, alternator, starter engine have been proven, finding if someone could pass me electrical scheme of this model to locate where that beast consumption comes from to that particular fuse.
Thank you very much and greetings!
