Chrysler Neon
9 years 9 months before #50792 by manual-mecanica
Manual-Mecanica Answer on the Chrysler Neon
You said "The RPM sensor is broken" they changed it several times and continues to break "
it is understood by breakage, that something is damaged by blow or abuse and now you clarify that it does not seem beaten and that apparently the problem is elèctric. The
problem should be up.
