Ford Ranger ignition system 2.3l 8 spark plug
9 years 7 months before - 9 years 7 months before #50775 by manual-mecanica
Ford Ranger ignition system 2.3l 8 spark plugs published by Manual-Mecanica
Hello, how I tell you I have a 1990 Ford Ranger truck 2.3L 4 STD cylinders of 8 spark plugs with ignition system, the problem is that it does not turn on, check gasoline pressure, pulses in the injectors, Crank sensor, DIS module, coils, compression in the cylinders, spark, etc Computer currents (EEC IV) and all good what he noticed was that when he marching sometimes he gave explosions as if he were out of time this made me check when he gave the spark and that is the problem "the progress of time is very advanced or backward" since it gives the spark at the wrong time, when seeing this it takes away the bridge of the spout signal because if you take this timing you do not 10 ° And it was in fact that he wanted to start but still a print that carries the truck says that in order to turn on the engine must be previously heated; My question is as follows: The problem of time progress is handled by the ECU or the DIS module ??? What can I do or recommend to start my truck?
Greetings I hope you can help me:(
Last edition: 9 years 7 months before by .
9 years 7 months before #50778 by manual-mecanica
If you remove the spout, the ignition is delayed.
The variation of the advance to the ignition is managed by the ECU.
The Mòdiculo DIS acts as an amplifier of the high tension generating not only a greater amount of spark but also more time of presence of the same, thus optimizing the combustion.
I think you could have the time band out of synchronization.
I leave you a band scheme so you can control it
9 years 7 months before #50784 by manual-mecanica
Thank you Brother, I tell you that you already check the alignment of brands and even change the time band is still the same.
In the same way I am almost convinced for what you tell me that it will be the computer if this is the one that regulates the progress of time, I am waiting for a friend to lend me his computer of his truck that is identical, but I am already desperate (15 days ago I am waiting for him) because he has not passed and I would not like to spend on an ECU if it is not necessary.
Looking on the Internet I read that either the ECU or some broken cable of signal voltage, tomorrow Checare to have come out and tell you
greetings
9 years 7 months before - 9 years 7 months before #50785 by manual-mecanica
There are then with the tests performed that:
-Ca has a spark, gasoline pressure, timely placed, etc.
-the progress of the time exaggeratedly is advanced
-by removing spout it is correctly delayed and verifies it
is what I have
9 years 7 months before #50808 by manual-mecanica
:( :( Hello, with the novelty that I put another identical computer that is working and that they believe that it remains exactly the same, the progress of time is not correct, which then checks that the crank sensor must give signal of 10 to 12 volts and only gives 8.5V, I do not know if this is the culprit, since in a tutorial that I saw on the Internet it must give a signal between 10 and 12 volts someone who knows more about this
. Ayuuuda !!: S : S : Pinch:
