No current
9 years 9 months before #50724 by manual-mecanica
No current published by Manual-Mecanica
Hello guys, I expose my problem, a few days ago that I have a corsa B, because it does not reach the spark plugs, I thought it could be the coil, but no, they change it and continue the same, I thought of a crankshaft sensor, but it is not, and well, well, I do not know where to look, I do not know that I had any starting fuse or hidden on, those that are in sight are checked and
9 years 9 months before #50726 by manual-mecanica
Manual-Mecanica response on the subject without current
There is no fuse for starting.
I ask: Is it with distributor and coil or only dry coil?
You have no spark in the spark plugs, but the injectors activate or during the start -up?
Answer this and we see.
9 years 9 months before - 9 years 9 months before #50728 by manual-mecanica
It does not go with a distributor, it is a coil, the spark plugs have no spark, we change coil and either, the nesters, then, carburetor with monopunt And we put new together, it was not done more,
Last edition: 9 years 9 months before by .
9 years 9 months before - 9 years 9 months before #50729 by manual-mecanica
Try to answer my questions promptly, that for something I ask them, when I do not have the car in question or at least one diagnosis by scanner I need to follow a series of steps to guide you in the fault, but it will be impossible to help you, for the moment I do not mind knowing, if it comes fuel or not, as I ask you I need that you tell me that if with the lack of spark there are either pulses in the injector or if you have them?
9 years 9 months before #50736 by manual-mecanica
Hello, control if the 12 V of food arrives at the coil and for the second one the signal of the rpm sensor may not arrive to know if they arrive control that the fuel pump works after the contact placed if it does not work after contact you will know that the rpm signal does not arrive.
