It is hard to put the 1st speed
16 years 11 months before #4401 by manual-mecanica
It is hard to put the 1st speed published by Manual-Mecanica
The car is a Renault Megane Scenic of 99 1.6 16V
on Friday the clutch and probe changed and everything went perfectly until Sunday the 1st does not enter soft must be forced
asks:
can it be that it can be badly regulating the rod that goes from the lever to the change?
16 years 11 months before #4402 by manual-mecanica
Manual-Mecanica response on the Re: it costs to put the 1st speed
Hello Imoggi, it may be that you have the change rod, a bit folded, or perhaps, the left motor support rolled forward, and sometimes it costs to put the first one, another thing is if your car equips hydraulic or cable clutch system, if it is cable to check the cable and its regulator, (it is automatic)
16 years 11 months before #4405 by manual-mecanica
Your problem remains clutch, adjust more regulation or press problems
16 years 11 months before #4408 by manual-mecanica
hello! For me the problem is still in the clutch, take it to the workshop and check it back. If you changed it you look if if the car begins to come out when you release the pedal and it is in the middle of the route.
16 years 11 months before #4409 by manual-mecanica
