PEUGEOT 806 SR
9 years 9 months before #50518 by manual-mecanica
Peugeot 806 SR published by Manual-Mecanica
Good and acquired a Puegeot 806 SR of the year 1995 .... I am from Chile to my country arrived as 40 units of this model the information is quite little ........... almost null ... I would like to know if someone in the group knows where the Scaner is connected since it presents a fault in relief in relief IAC I believe ... after accelerating ... Lower the rpm to 300 and then stabilize them ... and this occurs only once after each accelerated. ... The manual is already going down and the bad thing that is in French is great but we will try to translate
thank you very much
9 years 9 months before #50520 by manual-mecanica
Manual-Mecanica Response Peugeot 806 SR subject
Hello, it is undoubtedly the IAT or step -by -step valve you can wash where the problem is located, the problem is presented by carbon accumulation you can do it with a fuel cleaner itself washing the valve no and verifying that it does not help external air entry in manifest, some valves can be disassembled if that is your case is more than perfect to wash the accumulated carbon, greeting and luck.
