Start Mitsubishi Mirage Problem 2001
9 years 9 months before #50514 by manual-mecanica
MITSUBISHI MIRAGE START 2001 PUBLISHED BY MANUAL-MECANICA
I have a problem to start my car, it does not give me a starter, I already checked it and the coals are not burned, the Celenoid is in good condition, the problem is that when the Starter is cut the current to the Cleanoid. I have been able to start it, inciting the switch, could they help me solve my problem? I do the exception, my car is automatic.
9 years 9 months before #50532 by manual-mecanica
Manual-Mecanica Response on the subject of Mitsubishi Mirage 2001 Start
First see if it comes out sign of the contact sheet (black wire with yellow strip usually) then passes to the box selector that is so that it does not start if it is with change put on you must also check the relay that says ST in the fuse box that goes on the side of the engine. If with those points these are well connectors.
