Motor failure
10 years 2 days before - 10 years 2 days before #50420 by manual-mecanica
Motor failure published by Manual-Mecanica
I have a lincoln LS V6 2005 When I am circulating and it touches me bottling, let's say an hour of operation of the engine, the car begins to throw explosions and go out, I have to wait for the engine to cool and work again normally, they changed the gasoline pump and continues to do so. I have noticed that the engine is very hot, however the temperature indicator is normal, but not the engine, the heat is felt, I do not know if this has something to do with the aforementioned problem or the plane is the gasoline pressure regulator.
Any suggestion?
10 years 2 days before #50421 by manual-mecanica
Manual-Mecanica response on the subject failure in igniccion coil
Check the igniction coil, the most logices that the fault is in that piece, according to the description of the fault.
