Terrano acceleration problems 2, 2.7 TDI
10 years 6 days before #50409 by manual-mecanica
Terrano acceleration problems 2, 2.7 TDI published by manual-mecanica
Hello friends:
I have a terrain II: TD27ti engine
starts perfectly well, but when I try to accelerate, it has no power, I can push the accelerator to the bottom and the engine accelerates a little more than idle regime.
If I disconnect the flower connector, and stop the engine, after re -starting and accelerates and accelerates apparently well, if I connect the flowmeter again, again, all the power disappears and not accelerates.
I suppose the problem has to do with any of the many sensors related to the control of the injection pump, or the central itself (ECM).
I have the official technical manual, and I read it several times, but it seemed terribly complicated.
Is there any easy and logical test procedure that can be done for an amateur mechanic like me?
If I can't find the ruling, I know what touches me: take it to the official Nissan service and pay a lot of money.
Thank you
