Mercedes Benz 180d Diesel is hard to start humans
10 years 2 months before - 10 years 2 months before #50134 by manual-mecanica
Good morning, I am new in the forum ,,, I am having a problem with a Mercedes Benz 180 Mod 94 Diesel ,,, the problem is that it is costing you to start and when it starts it smooths a lot and when I stop it does not want to start back or it costs it and it continues to smoke what it could be the problem to guide me ,,, I would appreciate your help.
Latest edition: 10 years 2 months before by .
10 years 2 months before #50139 by manual-mecanica
Hello, check tension drop in booting should not get off 11 volt. I miss the engine, then remove the heaters and probate if it puts red before 5 sec, but are screwed. Some times they cost to start cold and hot directly does not start.
10 years 2 months before #50147 by manual-mecanica
Hello ...
the truth with a little more information type: smoke color? The smoke is just when sanging?
The previous answer would be the first and easier to check from the box of heaters but being hot to start without problems.
I would also buy diesel food towards the pump.
Another normal failure that makes smoke and bad start both cold and hot in the OM602 engine (that of your car) is the stretching of the chain. It would be checked by putting in Cuñañal in PMS. and releasing the lid of Valancines to verify that the camshaft is in its brand.
