Citroen saxo 1.1 gasoline does not start
10 years 2 months before - 10 years 2 months before #50135 by manual-mecanica
Manual-Mecanica response on the topic Citroen Saxo 1.1 Gasoline does not start
Hi Fiat 147, thanks for answering, it has been stopped around 3 years, and we do not fall into the waste that the gasoline can leave so the car stays with the tank in reserve, I must say that before the first start -up attempt, I bought 10l of new gasoline that will have been mixed with the liters of the reserve, the spark plugs bought new ones for their low cost in case, and the injectors have been cleaned. Do you recommend that you empty all the gasoline of the vehicle and load new just in case? Or can I have emboked any filter and therefore should I clean them?
The joints are new and everything is well sealed, no leaks are observed and everything is tight with their due Newton, since I have the necessary tools.
Thank you very much for your attention, I hope to find the solution soon!
Latest edition: 10 years 2 months before by .
10 years 2 months before #50136 by manual-mecanica
Hello,:) ... patience. 3 years is enough. Change all filters, blow the pipes with compressed air. Take out the tank pump, clean your prefilter (sieve), check that you are not glued. If you still do not start, you must measure fuel pressure, by the Shrader valve that has the riel of injection or attach another method in parallel. In any case, when giving contact, without starting the engine you must listen to the operation of the pump and then its stop (if you do not start), the above is normal., Good luck and tell us as you are waid.
10 years 1 month before #50171 by manual-mecanica
Good! Thank you all for your contribution!
In the end it has turned out to be a small cross between the valves, there was some evil regulated and when they greaton again, everyone has started again, so I give the subject for the end and again, thank you very much to everyone !!!
