No Compression Hyundai Matrix Compression
10 years 2 months before #50032 by manual-mecanica
No Compression Motor Hyundai Matrix published by Manual-Mecanica
Hello greetings to all my problem is that I have a Hyundai Matrix 2005 that the belly of time is revant ... We lower the cylinder head and there were 2 crooked valves we replace them we clean etc but now that we mounted the butt there is no compression in the engine we try outside the jiro of the camshafts and there are valves that remain open but when I remove the trees of
cams Canoso to think thanks ...
10 years 2 months before #50055 by manual-mecanica
Manual-Mecanica Answer on the subject without compression Hyundai Matrix
Is it an engine with hydraulic taes? If it is, they must be installed downloaded from its internal pressure.
