Chevrolet Aveo Failure Code 2011
10 years 3 months before #49980 by manual-mecanica
Failure Code at Chevrolet Aveo 2011 published by Manual-Mecanica
Good afternoon, I am new in the forum and I have a doubt, I scan my unit and I get the following code: P0135 O2 Heater Circuit Sensor (Bank 1 Sensor 1)
Someone knows what it is specifically.
I will appreciate your support
10 years 3 months before #49981 by manual-mecanica
Manual-Mecanica Response on the topic Failure Code at Chevrolet Aveo 2011
Hello, you can have a problem with the oxygen sensor heater circuit can be the connections or the probe would have to grab in tester and start measuring out there
10 years 3 months before #49983 by manual-mecanica
Change the ignition coil, the spark plugs already passes through that headache
