manual de mecanica del isuzu troper modelo88. con
10 años 10 meses antes #49666 por manual-mecanica
soy nuevo en este grupo y quisiera que me ayudaran a obtener el manual de isuzu troper modelo 88.
Qiuiero averiguar que significa los codigos 12--43--61 en la computadora del carro.
agradesco de antemano el que tenga la amavylidad de ayudarme.
gracias.
10 años 10 meses antes #49671 por manual-mecanica
Respuesta de manual-mecanica sobre el tema manual de mecanica del isuzu troper modelo88. con
Isuzu Check Engine Light Trouble Code Info
12 No tach signal to ECM – No Distributor Reference Pulses{4}
13 Oxygen sensor or circuit
14
Coolant Temperature Sensor Circuit
High Coolant Temperature{5}
14A
High Coolant Temperature{6}
14B
Low Coolant Temperature{6}
15
Low Coolant Temperature{5}{7}
16 Same as 15
21
TP Sensor And/Or Idle Switch
MAP Sensor{1}
TP Sensor, Voltage High{5}{7}
Throttle valve switch/Wide Open Throttle (WOT) position sensor, 1989 Manifold Absolute Pressure (MAP) circuit failure
Throttle Position Sensor (TPS) – V6 models
21A
TP Sensor, Voltage High{6}
21B
TP Sensor, Voltage Low{6}
22 Starter signal system/1988 and 1989 fuel cut solenoid circuit failure
TP Sensor
TP Sensor, Voltage Low{5}{7}
No Starter Signal{8}
Fuel Cut Off Relay{4}
23
MAT Sensor
MAT Sensor, Low Temp{7}
M/C Solenoid Circuit{4}
Mixture control solenoid circuit failure – 1987 and 1995 Amigo/Pick-up, 1989 to 1994 V6 models
Power transistor circuit – 1988 to 1994 four-cylinder models
Intake Air Temperature sensor voltage high – turbo, 1989 to 1995 1.6L, 1.8L, 3.2L vehicles
23A
MAT Sensor, Low Temp{6}
23B
MAT Sensor, High Temp{6}
24 Vehicle Speed Sensor (VSS) circuit – V6 models
Pressure regulator vacuum switching valve – 1988 to 1994 four-cylinder, also Impulse non-turbo
25
MAT Sensor
Vacuum Switching Valve{4}{9}
MAT Sensor, High Temp{7}
AIR VSV circuit failure
26
Canister Vacuum Switching Valve{4}
VSV System{9}
27
VSV System{9}
Constant Voltage High From VSV To ECM{4}
Fuel injector driver transistor
31
No Ignition Reference Pulses To ECM{4}
Wastegate Control{7}{8}
No ignition reference to ECM – 1988 and 1989 models
32 Exhaust Gas Recirculation (EGR) system failure
33
MAP Sensor
MAP Sensor, Voltage High{5}{7}
Fuel Injector{9}
33A
MAP Sensor, Voltage High–Low{6}
33B
MAP Sensor, Voltage Low–High{6}
34
MAP Sensor{8}{11}
MAP Sensor, Voltage Low{5}
EGR Gas Sensor Circuit{4}{7}
Fuel Injector{10}
35
MAP Sensor Constant Voltage High{4}
Power Transistor System{9}
36
MAP Sensor Circuit{4}
41
Crank Angle Sensor{9}
Cam Signal{7}
42
Electronic Spark Timing{5}
Ignition Control Circuit{6}{8}
43 Throttle valve switch/Wide Open Throttle (WOT) position sensor {9}
Electronic spark control failure – V6 models
Idle contact switch always closed (1988 to 1994 four-cylinder, also Impulse non-turbo)
Knock sensor (1989 to 1995 1.6L, 3.2L) {8}
44
O2S Lean
Fuel Metering{9}
45
Oxygen sensor (rich condition indicated)
Fuel Metering{9}
51
PROM{2}{8}
Fuel Cut Solenoid Circuit And/Or ECM{3} carbureted four-cylinder models
ECM{6}
MEM-CAL{7}
PROM, Cal-Park & ECM{5}
ROM and/or RAM{9}
52
ECM{4}
EEPROM{8}
ROM and/or RAM{9}
53
Switching Valve And/Or ECM{4}
Vacuum Switching Valve{9}
54
M/C (mixture control) Solenoid Circuit And/Or ECM{2}
Vacuum Control Solenoid And/Or ECM{3}
Fuel Pump, Voltage Low{5}{8}
Shorted vacuum control solenoid, Faulty Electronic Control Module (ECM) – 1988 and 1989 models
55
ECM{4}{8}
Faulty Electronic Control Module (ECM) or oxygen sensor
61 Air flow sensor circuit failure {9}
62 Air flow sensor circuit failure {9}
63 Vehicle Speed Sensor (VSS) circuit {9}
64 Fuel injector driver transistor {9}
65
Full throttle switch always on
66 Knock sensor circuit failure {9}
71 Throttle position switch signal abnormal {9}
72 VSV for EGR system short or open {9}
73 Same as 72 transister or ground {9}
