Calibrate pressure plate in Fuller Box
10 years 4 months before #49629 by manual-mecanica
Calibrate pressure plate in Fuller box published by Manual-Mecanica
Good evening, someone could explain how to calibrate the pressure dish in the clutch system of a Fuller box, since it seems to lose pressure and I cannot scar the speeds when I start. I appreciate any help ...
10 years 4 months before #49630 by manual-mecanica
Manual-Mecanica Response On the topic calibrate pressure plate in Fuller Box
Look for a 9/16 key removes the security lock and with a 5/8 llava you graduate it with someone inside to step on the clutch you have to verify why there are several locks. All that is below the transmission
10 years 3 months before #49831 by manual-mecanica
Manual-Mecanica Answer on the subject Algien could help me Conwindstar
With a problem with a windstar 96 because when I gala the engine all standard but when Suna Suna Something and restless and does not hear Neb
